The initial user name is default and the password is pass.
Synology DSM 7 Downloads
New Syncovery packages v12.9.1 for DSM 7 (install with Package Center):
DSM 7 Intel / AMD 64-Bit Package  DSM 7 Intel 32-Bit Package
DSM 7 ARM64 Package  DSM 7 ARM32 Package
Now over 50 Languages included.
Please note: when you install Syncovery on DSM 7 with these packages, it will no longer run as root.
You will need to edit the permissions of the folders and/or shares on your NAS to allow the new Syncovery user access.
You will find the pre-defined Syncovery user in the list of predefined users when editing folder permissions in File Station.
Just right-click a folder, click Properties, then Permissions. Choose “Apply to this folder, sub-folders and files”.
Click the Create button and choose the Syncovery user and give it all required permissions.
Alternatively, you can preserve root capabilities. To do so, you can use our new Syncovery Linux Installer Utility for Windows.
Download Syncovery Linux Installer Utility for Windows
The Syncovery Guardian is now included in the DSM 7 packages.
If you already have the standalone Guardian installed, you need to uninstall it before updating Syncovery with the native DSM7 packages.
Syncovery Remote Service v11.14.0 for DSM 7:
Synology 64-Bit Package (64-bit Intel / AMD processors)
Synology 32-Bit Package (32-bit Intel processors)
Synology ARM 32-Bit Package (ARM processors)
Synology ARM 64-Bit Package (ARM processors)
Please note: the Remote Service can also be installed with the Syncovery Linux Installer Utility for Windows.
Synology DSM 5/6 Downloads
Synology packages v12.9.1 for DSM 5/6 (install with Package Center):
Synology Intel / AMD 64-Bit Package  Synology Intel 32-Bit Package
Synology ARM64 Package  Synology ARM32 Package
Syncovery Guardian for DSM 5/6:
The Guardian restarts the main service if necessary to keep the web GUI accessible.
Synology ARM32 Package  Synology ARM64 Package  Synology ppc Package
Syncovery Remote Service v11.14.0 for DSM 6:
Synology ppc Package (PowerPC processors)
