This article is obsolete and applies only to version 5 of Super Flexible File Synchronizer for Linux.
The latest version of Syncovery for Linux is available as a native 64-bit application.
If you have a 64-bit Linux, you may have to install additional 32-bit libraries.
On the latest Ubuntu or Debian 64 bit (Wheezy), please do:
dpkg --add-architecture i386
aptitude update
libgtk2.0-0:i386 libsqlite3-0:i386The last two lines are actually one line.
Ubuntu users may have to add the multiarch sources in /etc/apt/sources.list
On older Ubuntu or Debian 64 bit distributions, do:
In addition, you may need:
See also Running 32-bit Applications on 64-bit Debian GNU/Linux.
If the program says it cannot find the sqlite3 libraries, you can download them from here (choose the i386 version), and install the downloaded file with these two commands at a root command prompt:
dpkg -X your_downloaded_lib_file_i386.deb /emul/ia32-linux (Enter) ldconfig (Enter)
