Context sensitive help is blank
fletch
Post by fletch »
I thought this used to work. Is the help content available elsewhere?
Re: Context sensitive help is blank
It depends on the Syncovery version. Some help problems were recently fixed.
You can always open Syncovery.chm from Windows File Explorer.
fletch
Post by fletch »
thanks! chm worked
The help problem was fixed in v10.16.3 for Windows from October 3rd, 2024.
It was caused by an incompatibility of Syncovery's visual themes and the help viewer program.
fletch
Post by fletch »
I'm at 10.16.9
But, once I manually opened the CHM, then closed it. Now F1 displays the help normally.
that's interesting. I don't have the problem here.
The behavior might still be different depend on visual theming settings.
