Default settings combined subfolders with similar names - how to change?
Iodine
Post by Iodine »
Hi All, syncovery is a fantastic program. I'm not sure how to change this setting though, it has never come up for me before.
I did a big sync of a directory, and the destination already had tons of media files in it. Syncovery found subfolders with matching names and combined them.
For example, both of these projects have a subfolder called "Uber Art" and now the files for both projects are in only 1 folder instead of each project having it's own sub folder called "Uber art"
Logs:
Going to check if higher level folder should be moved instead: \Ambition\Ambition_Art\Mezzanine Package to \A Walk To Remember\A_Walk_To_Remember_ProResHQ\A_Walk_To_Remember_Art
Remembering renamed folder on right side: \A Walk To Remember\A_Walk_To_Remember_ProResHQ\A_Walk_To_Remember_Art\Uber_Art
Moved folder   T:\Ambition\Ambition_Art\Mezzanine Package\Uber_Art
            to T:\A Walk To Remember\A_Walk_To_Remember_ProResHQ\A_Walk_To_Remember_Art\Uber_Art
The end result is that the Uber Art for "Ambition" is now in the Uber Art folder for "A walk to remember"
I would really love to know how to tweak or disable this feature so that I can maintain my directory structure and add to it without mixing projects up. Thanks in advance for your anticipated reply.
P.S. do you recommend I fix this manually or is there some way to fix it programmatically using syncovery? Thanks.
Re: Default settings combined subfolders with similar names - how to change?
this is done by the checkmark "Detect Moved Files and Renamed Folders".
A folder move or rename is only detected if both folders contain many of the same files.
You could turn this off.
I think you need to restore the previous state by manually moving folders back.
Was this a one-way or two-way sync?
If you like you could send the whole log file to support@syncovery.com, if it doesn't contain confidential file or folder names, so I can look into the problem in more details.
Iodine
Post by Iodine »
Thank you for the answer. I will fix it manually. It was a one way sync from 2 different servers onto a new server which will contain the combined elements of both of the old servers.
I will try disabling "Detect Moved Files and Renamed Folders"
