Excessive Logs on Synology
ChaosX
Post by ChaosX »
Got this message today
Then this...
But my settings sat 50!
FWIW, I dropped this to 10. At present I have 5 profiles (2 are disabled).
Thanks!
Re: Excessive Logs on Synology
the warning may have been caused by a slowness of the hard drive.
Maybe you can take a direct look at the Logs folder /volume1/.Syncovery/Logs using some other tool.
You could also request the re-count on the clean-up page until it does a full re-count.
The limit of 50 is per profile, so if you have many profiles, it can be 50 times the profile count.
ChaosX
Post by ChaosX »
I already reduced the settings so everything looks good now. I'll keep an eye on it. Thanks!
