Can not open left or right map or both
Auke
Post by Auke »
I am getting aplication error
when I try to open the left or right folder.
Scherm­afbeelding 2026-10-03 om 20.38.54.png (221.16 KiB) Viewed 57363 times
Syncovery has Full Disk Access
Does anyone have a hint?
Thanks,
Auke
Re: Can not open left or right map or both
exactly how do you "open the left or right folder"? Where do you click?
Which Syncovery version do you have?
Auke
Post by Auke »
I have version 12.8.9
I right-click on a profile and then go to open folder on left side , on right side, or on both sides
I also notice, by the way, that the hourglass often appears when I right-click on the profile and hover over the buttons.
many thanks. I can confirm the problem on Tahoe and will release a fix today.
the new version 12.8.11 fixes this. Apple changed an API function in Tahoe, without documenting it, which caused this error.
Auke
Post by Auke »
Everything is working again. Thanks for the quick fix.
