Syncovery on cachyOS / Arch Linux
julesbashaur
Post by julesbashaur »
Hey forum,
I run Syncovery on two Windows 11 machines creating daily on-premise (2nd hard drives and NAS via SMB) as well as remote backups (sftp).
Now, I like to change the OS to cachyOS, which is an Arch Linux based OS.
I am not that new to Linux, but certainly no expert.
My thought was to expor the Syncovery profiles, install Syncovery on cachyOS, import the profiles and there we go.
Sadly, there is no package that is compatible with Arch Linux.
I therefore choose the Debian .deb package and transformed it using debtap.
This package I could install and create a daemon. The daemon does not start properly:
systemctl status syncoverycl:
syncoverycl.service - Syncovery Web Service
Loaded: loaded (/etc/systemd/system/syncoverycl.service; enabled; preset: disabled)
Active: failed (Result: start-limit-hit) since Thu 2025-12-25 12:51:37 CET; 48min ago
Duration: 1.349s
Invocation: 7d6505ea7d5042fd85af99c5226da29a
Process: 1216 ExecStart=/usr/lib/Syncovery/Misc/syncoverycl (code=exited, status=0/SUCCESS)
Main PID: 1216 (code=exited, status=0/SUCCESS)
Mem peak: 5.2M
CPU: 45ms
Dez 25 12:51:37 schleifer-pc-cachyos systemd[1]: syncoverycl.service: Scheduled restart job, restart counter is at 5.
Dez 25 12:51:37 schleifer-pc-cachyos systemd[1]: syncoverycl.service: Start request repeated too quickly.
Dez 25 12:51:37 schleifer-pc-cachyos systemd[1]: syncoverycl.service: Failed with result 'start-limit-hit'.
Dez 25 12:51:37 schleifer-pc-cachyos systemd[1]: Failed to start Syncovery Web Service.
journalctl -u syncoverycl.service -n 50 yields the following:
Dez 25 12:51:32 schleifer-pc-cachyos systemd[1]: syncoverycl.service: Deactivated successfully.
Dez 25 12:51:33 schleifer-pc-cachyos systemd[1]: syncoverycl.service: Scheduled restart job, restart counter is at 2.
Dez 25 12:51:33 schleifer-pc-cachyos systemd[1]: Started Syncovery Web Service.
Dez 25 12:51:34 schleifer-pc-cachyos SyncoveryCL[1118]: Syncovery 11.11.11, build 141, English: [Info] SyncoveryCL v11.11.11 started with command line /usr/lib/Syncovery/SyncoveryCL
Dez 25 12:51:34 schleifer-pc-cachyos syncoverycl[1118]: 12:51:34 SyncoveryCL v11.11.11
Dez 25 12:51:34 schleifer-pc-cachyos syncoverycl[1118]: Reading config file /etc/SyncoveryCL.conf
Dez 25 12:51:34 schleifer-pc-cachyos syncoverycl[1118]: Temp folder from /etc/SyncoveryCL.conf: /tmp/
Dez 25 12:51:34 schleifer-pc-cachyos syncoverycl[1118]: 12:51:34 Initializing
Dez 25 12:51:34 schleifer-pc-cachyos syncoverycl[1118]: 12:51:34 Opening Database
Dez 25 12:51:34 schleifer-pc-cachyos syncoverycl[1118]: 12:51:34 Looking for database backup file
Dez 25 12:51:34 schleifer-pc-cachyos syncoverycl[1118]: 12:51:34 Log folder: /root/.Syncovery/Logs
Dez 25 12:51:34 schleifer-pc-cachyos syncoverycl[1118]: 12:51:34 Configuration File: /root/.Syncovery/Syncovery.cfg
Dez 25 12:51:34 schleifer-pc-cachyos syncoverycl[1118]: 12:51:34 Limited Free Edition. Remaining Pro Evaluation Days: 29
Dez 25 12:51:34 schleifer-pc-cachyos syncoverycl[1118]: 12:51:34 Parameter not recognized:
Dez 25 12:51:34 schleifer-pc-cachyos SyncoveryCL[1118]: Syncovery 11.11.11, build 141, English: [Info] Limited Free Edition. Remaining Pro Evaluation Days: 29
Dez 25 12:51:34 schleifer-pc-cachyos systemd[1]: syncoverycl.service: Deactivated successfully.
Dez 25 12:51:34 schleifer-pc-cachyos systemd[1]: syncoverycl.service: Scheduled restart job, restart counter is at 3.
Dez 25 12:51:34 schleifer-pc-cachyos systemd[1]: Started Syncovery Web Service.
Dez 25 12:51:35 schleifer-pc-cachyos SyncoveryCL[1130]: Syncovery 11.11.11, build 141, English: [Info] SyncoveryCL v11.11.11 started with command line /usr/lib/Syncovery/SyncoveryCL
Dez 25 12:51:35 schleifer-pc-cachyos syncoverycl[1130]: 12:51:35 SyncoveryCL v11.11.11
Dez 25 12:51:35 schleifer-pc-cachyos syncoverycl[1130]: Reading config file /etc/SyncoveryCL.conf
Dez 25 12:51:35 schleifer-pc-cachyos syncoverycl[1130]: Temp folder from /etc/SyncoveryCL.conf: /tmp/
Dez 25 12:51:35 schleifer-pc-cachyos syncoverycl[1130]: 12:51:35 Initializing
Dez 25 12:51:35 schleifer-pc-cachyos syncoverycl[1130]: 12:51:35 Opening Database
Dez 25 12:51:35 schleifer-pc-cachyos syncoverycl[1130]: 12:51:35 Looking for database backup file
Dez 25 12:51:35 schleifer-pc-cachyos syncoverycl[1130]: 12:51:35 Log folder: /root/.Syncovery/Logs
Dez 25 12:51:35 schleifer-pc-cachyos syncoverycl[1130]: 12:51:35 Configuration File: /root/.Syncovery/Syncovery.cfg
Dez 25 12:51:35 schleifer-pc-cachyos syncoverycl[1130]: 12:51:35 Limited Free Edition. Remaining Pro Evaluation Days: 29
Dez 25 12:51:35 schleifer-pc-cachyos syncoverycl[1130]: 12:51:35 Parameter not recognized:
Dez 25 12:51:35 schleifer-pc-cachyos SyncoveryCL[1130]: Syncovery 11.11.11, build 141, English: [Info] Limited Free Edition. Remaining Pro Evaluation Days: 29
Dez 25 12:51:36 schleifer-pc-cachyos systemd[1]: syncoverycl.service: Deactivated successfully.
Dez 25 12:51:36 schleifer-pc-cachyos systemd[1]: syncoverycl.service: Scheduled restart job, restart counter is at 4.
Dez 25 12:51:36 schleifer-pc-cachyos systemd[1]: Started Syncovery Web Service.
Dez 25 12:51:37 schleifer-pc-cachyos SyncoveryCL[1220]: Syncovery 11.11.11, build 141, English: [Info] SyncoveryCL v11.11.11 started with command line /usr/lib/Syncovery/SyncoveryCL
Dez 25 12:51:37 schleifer-pc-cachyos syncoverycl[1220]: 12:51:37 SyncoveryCL v11.11.11
Dez 25 12:51:37 schleifer-pc-cachyos syncoverycl[1220]: Reading config file /etc/SyncoveryCL.conf
Dez 25 12:51:37 schleifer-pc-cachyos syncoverycl[1220]: Temp folder from /etc/SyncoveryCL.conf: /tmp/
Dez 25 12:51:37 schleifer-pc-cachyos syncoverycl[1220]: 12:51:37 Initializing
Dez 25 12:51:37 schleifer-pc-cachyos syncoverycl[1220]: 12:51:37 Opening Database
Dez 25 12:51:37 schleifer-pc-cachyos syncoverycl[1220]: 12:51:37 Looking for database backup file
Dez 25 12:51:37 schleifer-pc-cachyos syncoverycl[1220]: 12:51:37 Log folder: /root/.Syncovery/Logs
Dez 25 12:51:37 schleifer-pc-cachyos syncoverycl[1220]: 12:51:37 Configuration File: /root/.Syncovery/Syncovery.cfg
Dez 25 12:51:37 schleifer-pc-cachyos syncoverycl[1220]: 12:51:37 Limited Free Edition. Remaining Pro Evaluation Days: 29
Dez 25 12:51:37 schleifer-pc-cachyos syncoverycl[1220]: 12:51:37 Parameter not recognized:
Dez 25 12:51:37 schleifer-pc-cachyos SyncoveryCL[1220]: Syncovery 11.11.11, build 141, English: [Info] Limited Free Edition. Remaining Pro Evaluation Days: 29
Dez 25 12:51:37 schleifer-pc-cachyos systemd[1]: syncoverycl.service: Deactivated successfully.
Obviously, the text "Syncovery 11.11.11, build 141, English: [Info] Limited Free Edition. Remaining Pro Evaluation Days: 29" is not a recognized parameter in /root/.Syncovery/Syncovery.cfg.
As a side note, you may notice that the trial period timer works just fine. :)
Any ideas how I can repair syncovery.cfg or rectify the error another way?
Maybe there is an easier and/or more robust way to install Syncovery in the first place?
Re: Syncovery on cachyOS / Arch Linux
I don't know exactly where the problem is. It should not be in Syncovery.cfg. Also, the "Parameter not recognized" error is probably related to something else, not the line following it.
Last time I tried Arch Linux, I could install the Debian package natively. Arch Linux has dpkg too, or at least it can be installed.
So you can install Syncovery natively with
sudo dpkg -i Syncovery-11.11.14-amd64.deb
If problems remain, it would be interesting to see the output when you simply enter
SyncoveryCL
This should start the process in the foreground, i.e. you will see useful messages in the Terminal. And you can try accessing the browser based GUI via localhost:8999.
You can also check the logs folder for files like SyncoveryCL_Exceptions.log and send it to me, if it exsists.
julesbashaur
Hey tobias,
thank you for the quick reply!
I knew about dpkg, but I was recommended to not use it.
Nevertheless, dpkg did the trick. The daemon works without any adjustments and I can open the WebGUI. :)
