v10 -> v11 my single FTP profile quit working
fletch
Post by fletch »
Not sure what to look for or check. Worked every day on v10. Just upgraded to v11 Monday.
The strange part - on the IP Settings dialog when I click the folder button, it connects and shows the folders on the site - and I can navigate through them.
11.0.14
*edit*
FWIW, I have another FTP profile that I'm no longer using that connects to an FTP server provided via my Domain service. That one works. The one that connects to my routers FTP is the one that stopped working with v11.
ftp://192.168.1.1/NCW-Images
Port 21
Passive
Lib 3, whatever that is
Re: v10 -> v11 my single FTP profile quit working
please send a complete log file to support@syncovery.com.
There are no known problems.
the new version 11.0.16 should fix this now! Thanks for the report.
There was an error with a CWD command, caused by recent adjustments for OpenVMS FTP servers.
fletch
Post by fletch »
Confirmed fixed - 31,000 files moved this morning - thank you!
spoidyjan
Contact:
Post by spoidyjan »
Was the CWD issue only with certain FTP servers, or could it happen with any setup? I want to be sure my profiles will work fine after upgrading.
the CWD issue could affect any FTP server under certain conditions, but it has been fixed and it's history and not relevant any more.
spoidyjan
Contact:
Post by spoidyjan »
Thankyou for your response.
