Quickly add job or global exclusion from preview?
fletch
Post by fletch »
As I setup several profiles and run the job to analyze the preview, I discover some files I want to exclude. It would be useful to be able to add either job or global exclusions from the preview window - via right-click. At the least be able to copy the filename.
Re: Quickly add job or global exclusion from preview?
yes it's currently easy to exclude a folder in the Sync Preview, but not individual files. You can exclude a file for this run only by choosing "Remote From List" (F5) or "Leave Alone" (F7).
To exclude a file and save the exclusion in the profile, you can choose "Apply New Exclusion Mask" and then type the filename.
fletch
Post by fletch »
Ok. Wish list item :idea: :D
* auto-fill dialog with name
* option to add to global list. Obviously change "Use" to "Add to"
