Collapsed groups & clicking
fletch
Post by fletch »
If collapsed, single-click should not expand them. IMO
Odd things that don't seem right
Double-click collapsed group opens up the group, brings up the edit profile window for the first entry in the group, then collapses the group
Double-click expanded group collapses the group and brings up the edit profile window for the first entry in the group
If double-click only expanded collapsed groups and single click on the group did nothing, that would be great.
I plan to create LOTS of groups, some of which I run manually and only monthly. So I'd like to keep them collapsed and not have to worry about single-clicking in the wrong place and opening that group - which has a dozen entries :o
Re: Collapsed groups & clicking
OK, I'll check it.
