Including only Specific Repeating Folder
AJMarek
Post by AJMarek »
I'm having trouble getting Syncovery v11 to accomplish something with Inclusion Masks.
Scenario structure is lots of higher level folders with the same folder underneath each
Folder A
\Sub1
\Sub2
Folder B
\Sub1
\Sub2
I want to backup the structure (so it includes the Folder A level) but only \Sub2 for every one of them. Each in their own little tree so I know who belongs to whom.
I'm coming up empty trying with an Inclusion Mask where it is very easy with an Exclusion Mask if I wanted to do the opposite. I don't want to populate a big Exclusion Mask to leave \Sub2 because the structure is not always the same. \Sub2 is always there, but other folders change.
Ideas please and thank you!
Re: Including only Specific Repeating Folder
in this case, please leave the Inclusion Masks field completely empty.
Choose the "Folder Masks" checkbox below, and type
Sub2
in the pop-up dialog box. Leave the first two checkmarks checked and the last two unchecked.
I hope this works for you!
AJMarek
Post by AJMarek »
I really appreciate the quick reply and I had stumbled upon this very easy solution after I posted (I must have missed this simple combination) and was making this far more complicated than it really is. My backup was successful and exactly what I was looking for. Thanks!
