problem with function OnCanRunProfile
PeterC
Post by PeterC »
I had a 'Global PascalScript for All Profiles' running that prevents two profiles from running at once.
I renamed one of the profiles and edited the names in the script but now the script is not preventing the two from running.
Screenshots showing the profiles:
20241016 p1.jpg (34.1 KiB) Viewed 9107 times
20241016 p2.jpg (30.45 KiB) Viewed 9107 times
The function:
const p1='[chn00] C:\(slctd,excl)--SamsungT7-L:\UserData';
      p2='Winbirra Daily L:30-min Backup C&D--Wombat (sleep)';
function OnCanRunProfile(const ProfileName:UnicodeString; var PostponeBySeconds:Integer):Boolean;
  if ProfileName=p1 then
     Result:=not ProfileRunning(p2)
  else
     if ProfileName=p2 then
       Result:=not ProfileRunning(p1)
     else
       Result:=true;
  if not Result then
     PostponeBySeconds:=60;
Any help will be greatly appreciated!
Re: problem with function OnCanRunProfile
many thanks for your post!
Due to the new free grouping feature in Syncovery 10, it's not possible for me to verify the actual profile names from your screenshots. Can you post the actual names from screenshots of the profile editor dialog or a log file?
Thanks.
PeterC
Post by PeterC »
20241016 profile p1.jpg (17.53 KiB) Viewed 9097 times
20241016 profile p2.jpg (16.9 KiB) Viewed 9097 times
PeterC
Post by PeterC »
It seems to be working again. Please close this request.
Thanks for looking at it promptly.
