Feature suggestion: Compress/encrypt by file extension
» by
Post by » by »
I'm having some difficulty organizing my local storage, cloud storage, and Syncovery profiles. Part of the difficulty is that Syncovery profiles are all-or-nothing when it comes to enabling/disabling/configuring both compression and encryption.
For example, I don't want to compress or encrypt my huge system image files, because they are already compressed and encrypted, and doing it in Syncovery is a huge waste of time and resources.
On the other hand, I like to encrypt large videos, but trying to compress them would be a pointless waste.
It would be fantastic to be able to choose which file types (extensions) to compress and/or encrypt in a single Syncovery profile, and which settings to apply (e.g. compression level). Without this capability, I find myself organizing my local storage and Syncovery profiles not by what I'm backing up to Google Drive, but rather by how compression/encryption needs to be handled by Syncovery.
Thanks for reading!
» by
Re: Feature suggestion: Compress/encrypt by file extension
Post by » by »
If I'm missing something, I'd appreciate someone pointing it out. Was this a ridiculous suggestion? Is my entire thought process on this broken?
spoidyjan
Contact:
Post by spoidyjan »
Great Suggestion.
Flexibility based on file extensions would make Syncovery much more efficient. For example, when handling large image files, I personally use an image compressor tool to optimize them beforehand. It’s always helpful to have tailored solutions for different file types to save 8-) time and resources.
calcu007
Post by calcu007 »
You use 1 option too, Encrytion or compression y you want.
» by
Post by » by »
calcu007 wrote: Sat Feb 15, 2025 3:45 pm You use 1 option too, Encrytion or compression y you want.
I have no idea what you're trying to say.
calcu007
Post by calcu007 »
I mean you can use 1 option only encrypt or compress.
» by
Post by » by »
Right, but that doesn't address my issue. Thanks.
IMTheNachoMan
Post by IMTheNachoMan »
I have a hack solution.
Create multiple profiles with their own include/exclude masks.
One profile does everything but system image files and does encrypt. One profile that does just system image files and does not encrypt.
Hacky but it should work?
» by
Post by » by »
Thanks. That's pretty much what I'm currently doing, except that I need more than two profiles because of having several "categories" of files (based on desired to encrypt and/or compress).
sorry for the late reply, but on the Program Settings dialog, tab sheet "Types, Limits", you can specify file types not to compress, such as:
*.mp4;*.avi
