OneDrive errors (syncovery version 10.14.3 64bit)
jma
Post by jma »
I'm testing the trial version 10.14.3 64bit
I use the OneDrvNew protocol.
My left hand side is a local folder, the right side is ext://OneDrvNew/Backups/Camera
When I try to upload larger files (+- 40MB) I get errors, while smaler files don't give any problem.
Below I paste a part of the log, I'm omitting some lines because they contain url's.
Does anybody have an idea what could be wrong here?
Is there also an option not to try 6 times?
Thanks in advance.
IndyLogging to G:\Tools\Syncovery\Temp\FTPLOG-WORKING-Camera test (started 2024-04-24 10.58.15).thread1#8268.log, IOresult=0
Connecting with OneDrvNew
Loaded libssl-3-x64.dll
Loaded libcrypto-3-x64.dll
Using OpenSSL 3.2.0 23 Nov 2023: libssl-3-x64.dll, libcrypto-3-x64.dll
24/04/2024 10:58:16 HTTP Request GET to https://api.onedrive.com/v1.0/drive with timeouts: 600000, connection 600000, transfer 0
24/04/2024 10:58:22 LeaveAuthSection, FInCheckDriveConnected=0
24/04/2024 10:58:31 OneDrvNew: IP Log File: G:\Tools\Syncovery\Temp\FTPLOG-WORKING-Camera test (started 2024-04-24 10.58.15).thread1#8268.log
24/04/2024 10:58:34 OneDrvNew: Starting upload of 00005.d20190202-u145257.mp4.s43939127.7z (43924058 Bytes)
24/04/2024 10:58:35 OneDrvNew: Uploading chunk #0
24/04/2024 10:59:05 OneDrvNew: Exception uploading 00005.d20190202-u145257.mp4.s43939127.7z: Upload Error 404: Not Found (ETGFTPError), CP:BTFOutX
24/04/2024 10:59:05 OneDrvNew: Retrying: 00005.d20190202-u145257.mp4.s43939127.7z
24/04/2024 10:59:05 OneDrvNew: Starting upload of 00005.d20190202-u145257.mp4.s43939127.7z (43924058 Bytes)
24/04/2024 10:59:07 OneDrvNew: Uploading chunk #0
24/04/2024 10:59:14 OneDrvNew: Exception uploading 00005.d20190202-u145257.mp4.s43939127.7z: Upload Error 404: Not Found (ETGFTPError), CP:BTFOutX
24/04/2024 10:59:14 OneDrvNew: Retrying: 00005.d20190202-u145257.mp4.s43939127.7z
24/04/2024 10:59:14 OneDrvNew: Starting upload of 00005.d20190202-u145257.mp4.s43939127.7z (43924058 Bytes)
24/04/2024 10:59:15 OneDrvNew: Uploading chunk #0
24/04/2024 10:59:23 OneDrvNew: Exception uploading 00005.d20190202-u145257.mp4.s43939127.7z: Upload Error 404: Not Found (ETGFTPError), CP:BTFOutX
24/04/2024 10:59:23 OneDrvNew: Retrying: 00005.d20190202-u145257.mp4.s43939127.7z
24/04/2024 10:59:23 OneDrvNew: Starting upload of 00005.d20190202-u145257.mp4.s43939127.7z (43924058 Bytes)
24/04/2024 10:59:24 OneDrvNew: Uploading chunk #0
24/04/2024 10:59:31 OneDrvNew: Exception uploading 00005.d20190202-u145257.mp4.s43939127.7z: Upload Error 404: Not Found (ETGFTPError), CP:BTFOutX
24/04/2024 10:59:31 OneDrvNew: Retrying: 00005.d20190202-u145257.mp4.s43939127.7z
24/04/2024 10:59:32 OneDrvNew: Starting upload of 00005.d20190202-u145257.mp4.s43939127.7z (43924058 Bytes)
24/04/2024 10:59:33 OneDrvNew: Uploading chunk #0
24/04/2024 10:59:40 OneDrvNew: Exception uploading 00005.d20190202-u145257.mp4.s43939127.7z: Upload Error 404: Not Found (ETGFTPError), CP:BTFOutX
24/04/2024 10:59:40 OneDrvNew: Retrying: 00005.d20190202-u145257.mp4.s43939127.7z
24/04/2024 10:59:40 OneDrvNew: Starting upload of 00005.d20190202-u145257.mp4.s43939127.7z (43924058 Bytes)
24/04/2024 10:59:41 OneDrvNew: Uploading chunk #0
24/04/2024 10:59:48 OneDrvNew: Exception uploading 00005.d20190202-u145257.mp4.s43939127.7z: Upload Error 404: Not Found (ETGFTPError), CP:BTFOutX
24/04/2024 10:59:48 OneDrvNew: Final exception uploading 00005.d20190202-u145257.mp4.s43939127.7z: Upload Error 404: Not Found (ETGFTPError) (6 attempts uploading stream) (EFinalCloudException)
IndyLogging to G:\Tools\Syncovery\Temp\FTPLOG.thread3#6592.log, IOresult=0
24/04/2024 10:59:48 ERROR (ETGFTPError): Upload Error 404: Not Found @ 00000000023556CC, Thread ID: 6592, CP: CbFTPStatX (CloudUpload)
Exception Upload Error 404: Not Found (ETGFTPError) (6 attempts uploading stream) at 0000000001988960.
Filename: G:\Tools\Syncovery\Temp\Backup 10160.2304.33554433.6592-4815687-998522135.7z
Checkpoints: TGGetOrPutEX:Upload Error 404: Not Found (ETGFTPError) (6 attempts uploading stream)
Errors / Access problems with 1 File:
\201909 Tokyo\00005.mp4 (Upload Error 404: Not Found (ETGFTPError) (6 attempts uploading stream) at 0000000001988960.CP: BTFOutX)
Main Copying Phase Ended At 24/04/2024 10:59:49 And Took 00:01:17
Re: Ondrive errors (syncovery version 10.14.3 64bit)
it seems that the OneDrive server is having a problem. It doesn't happen with my own OneDrive accounts. Apparently not all OneDrives are equal, i.e. the server software can be different from one OneDrive account to another.
Since you have already enabled Internet Protocol Logging, could you maybe send a few of the FTPLOG files to support@syncovery.com?
For example:
But there are others too, I am not sure which one exactly I need, but it would contain the 404 error.
jma
Post by jma »
Hi Tobias,
Thanks for the quick reply.
As requested I emailed the log.
Kind regards
jma
Re: OneDrive errors (syncovery version 10.14.3 64bit)
Post by jma »
Got an update from Tobias and everything is working like a charm now.
Version 10.14.4 is now officially on our web site.
Thanks!
