Traverse Exception ERangeError
KCarterSr
Post by KCarterSr »
I'm evaluating the Linux version of the software. It's by far the best one I've seen so far for Linux.
I'm really impressed and hope I can figure this out.
It's working with most directories but one keeps giving me errors. It worked the first time but never again.
I've tried everything I can think of. Even deleted the source directory and started from scratch. But, it refuses to read the sub-directories.
The Google drive is mounted via RClone and works perfectly. I'm only using 1 thread in Syncovery.
Any other Rclone mount directories using Syncovery WORKS GOOD.
I can see everything in the folder in the OS, and doing any operations though the OS File browser works perfectly.
Here is the log.
Note:
I WOULD ADD THE FULL TEXT BUT YOU HAVE A 50000 CHARACTER LIMIT, AND i
CAN'T ATTACH THE FILE BECAUSE IT SEEMS LIKE YOU HAVEN'T ENABLED ANY FILE EXTENSIONS
IN YOU ADMIN PANEL FOR ATTACHMENTS.
Syncovery v8.68c, build 385 (64-bit CL)
Remaining days for evaluation: 28
Running on : Debian-104-buster-64-LAMP
Running as : root
System Info: Linux Debian-104-buster-64-LAMP 4.19.0-9-amd64 #1 SMP Debian 4.19.118-2+deb10u1 (2020-06-07) x86_64 GNU/Linux
Log for profile Update Google Drive Encrypted Folder, started at 19:29:03 on 08/12/2020
LEFT: /mnt/G Suite Google Drive Root Drive Not Encrypted/Encrypted
RIGHT: /mnt/G Suite Google Drive Root Drive Not Encrypted/test
The profile is executed in the background with Sync Preview
LastRun from INI: 08/12/2020 19:24:09, LastRun var: 08/12/2020 19:29:03, OriginalLastRun: 08/12/2020 19:24:09
TGUseIniWrite: /etc/.Syncovery/Syncovery.cfg
TGUseIniRead: /etc/.Syncovery/Syncovery.cfg
PrefsReadOnly: FALSE, IniFileReadOnly: FALSE
Previous run was at 08/12/2020 19:24:09: Access problem (Range check error, Checkpoints: In CleanFiles, CP 2 @000000000113AA8B)
Preparing Left Selection: , base=\mnt\G Suite Google Drive Root Drive Not Encrypted\Encrypted
Preparing Right Selection: , base=\mnt\G Suite Google Drive Root Drive Not Encrypted\test
Scanning Folders Started At 08/12/2020 19:29:03
19:29:03 Now in "Traverse" level 0:
. OnlySelected=N
SubfolderSelections=
UseFolderMasks=FALSE, FolderMasks=
19:29:03 Calling FindFirst(/mnt/G Suite Google Drive Root Drive Not Encrypted/Encrypted/*)
19:29:03 FindFirst(/mnt/G Suite Google Drive Root Drive Not Encrypted/Encrypted/*)=0
19:29:03 2n1m7mt7qo6gmu3cup79t0k604: itMatches=TRUE, isDir=TRUE, DontCopy=FALSE, orig:
IgnoreMasksAndSelection=FALSE, OnlySelected=FALSE, Right=FALSE, FlatRightSide=FALSE
19:29:03 2n1m7mt7qo6gmu3cup79t0k604: added.
19:29:03 4jl47kir7o06g3g6p4j0nimgtc: itMatches=TRUE, isDir=TRUE, DontCopy=FALSE, orig:
19:29:03 4jl47kir7o06g3g6p4j0nimgtc: added.
19:29:03 4qjkid91iv65o4rd5qb7k0g2sk: itMatches=TRUE, isDir=TRUE, DontCopy=FALSE, orig:
19:29:03 4qjkid91iv65o4rd5qb7k0g2sk: added.
19:29:03 5mk0rv4i88cpeu4p1nfdfigmdtp5ea93c377m5b8l9s0o357601g: itMatches=TRUE, isDir=TRUE, DontCopy=FALSE, orig:
19:29:03 5mk0rv4i88cpeu4p1nfdfigmdtp5ea93c377m5b8l9s0o357601g: added.
19:29:03 65v1m0okr92tp999kb2s1d3fng: itMatches=TRUE, isDir=TRUE, DontCopy=FALSE, orig:
19:29:03 65v1m0okr92tp999kb2s1d3fng: added.
19:29:03 bc3d9kb6srsppbt3n80gbjlu34: itMatches=TRUE, isDir=TRUE, DontCopy=FALSE, orig:
19:29:03 bc3d9kb6srsppbt3n80gbjlu34: added.
19:29:03 ej811e5pqmiogjkba4h2g9kceo: itMatches=TRUE, isDir=TRUE, DontCopy=FALSE, orig:
19:29:03 ej811e5pqmiogjkba4h2g9kceo: added.
19:29:03 j6f13a8hu7qhm54hsoc2homieg: itMatches=TRUE, isDir=TRUE, DontCopy=FALSE, orig:
19:29:03 j6f13a8hu7qhm54hsoc2homieg: added.
19:29:03 kicrtfp5kkmiepnb73c2g40v2gbdvrl4m7ptnilkjiv457mgpmpg: itMatches=TRUE, isDir=TRUE, DontCopy=FALSE, orig:
19:29:03 kicrtfp5kkmiepnb73c2g40v2gbdvrl4m7ptnilkjiv457mgpmpg: added.
19:29:03 vvl6vt81jhf66dis6nt8ctqulqmdgquku9uk5tuvv0vompmb66kn8heckj91k28b1d3sisrv4fsta: itMatches=TRUE, isDir=TRUE, DontCopy=FALSE, orig:
19:29:03 vvl6vt81jhf66dis6nt8ctqulqmdgquku9uk5tuvv0vompmb66kn8heckj91k28b1d3sisrv4fsta: added.
08/12/2020 19:29:03 Sorting 10 files, Right=FALSE CaseSensitiveFileNamesMode=FALSE
08/12/2020 19:29:03 Sorting 10 files complete.
19:29:03 Result: 10 RightFilteredFolderCount: 0 RightFilteredFileCount: 0 LeftFilteredFolderCount: 0 LeftFilteredFileCount: 0
19:29:03 Calling FindFirst(/mnt/G Suite Google Drive Root Drive Not Encrypted/test/*)
19:29:03 FindFirst(/mnt/G Suite Google Drive Root Drive Not Encrypted/test/*)=18
LegitNotFound:TRUE, hasDotDirs:FALSE, FileMaskToUse:*
08/12/2020 19:29:03 Sorting 0 files, Right=TRUE CaseSensitiveFileNamesMode=FALSE
08/12/2020 19:29:03 Sorting 0 files complete.
19:29:03 Result: 0 RightFilteredFolderCount: 0 RightFilteredFileCount: 0 LeftFilteredFolderCount: 0 LeftFilteredFileCount: 0
19:29:03 Find Files: /mnt/G Suite Google Drive Root Drive Not Encrypted/Encrypted/* = 10 and /mnt/G Suite Google Drive Root Drive Not Encrypted/test/* = 0
Item 2n1m7mt7qo6gmu3cup79t0k604, st_dev: 000000000000002B, st_ino: Traverse Exception ERangeError: Range check error @000000000113AA8B, Checkpoints: In CleanFiles, CP 2
08/12/2020 19:29:04 ERROR (ERangeError): Range check error, Checkpoints: In CleanFiles, CP 2 @000000000113AA8B @ 000000000113AA8B Thread ID: 59729664
Application Error At 000000000113AA8B on 08/12/2020 19:29:04
Exception ERangeError: Range check error, Checkpoints: In CleanFiles, CP 2 @000000000113AA8B
Executable: /usr/lib/Syncovery/SyncoveryCL
Reporting Thread ID: 59729664Size: 22006224 (64-bit)
Checkpoints: ATTHR: Y/Y/ATTHR: Y/Y
Parameter: start
Client Pipes: 0, Threads: 0
Server Pipes: 2, Threads: 2
Stack Trace
Exception class: ERangeError
Re: Traverse Exception ERangeError
thanks, this gives me something to work with.
What if you turn off "File List Building Details" on the Program Settings dialog, tab sheet Logs? That will avoid unnecessary logging, and possibly avoid the line of code causing the error.
KCarterSr
Post by KCarterSr »
Yes, that worked.
Thank you
