Files are moved on Left Side, when exact Mirror from Left to Right is used
Ibeme
Post by Ibeme »
I currently do have a strange problem with Syncovery and I don't know what the cause of it is.
A Exact Copy is used from left to right with default Settings.
After the initial Copy from Left to Right I started the Profile in attended mode again.
Now it wan't to move some files on the left side instead of moving or creating them on the right side.
I don't know what exactly causes this because the exact mirror shouldn't move any Files on the Left Side.
When I rename the Folder on the Rights Side it wants to move even more data on the Left Side.
Any idea what could be the problem?
Re: Files are moved on Left Side, when exact Mirror from Left to Right is used
it's probably a bug caused by the smarter move logic introduced recently. I will look into it and fix it immediately.
Which Syncovery version do you have?
Ibeme
Post by Ibeme »
As additional info:
I just updated to the newest version 10.9.5 but the problem persists.
When I enable to detect renames it doesn't seem to move anything on the Left Side.
But I never had to enable it before.
I'm waiting for your findings. :)
Thank you in advance.
Update:
On another Profile on which this happens even detect renames doesn't help.
this has been fixed in version 10.9.6 now. I do not generally recommend the option "Detect Renamed Files" because it's based on file size and mofification dates only, not the actual content. So there could sometimes be incorrect detections of a renamed file.
Ibeme
Post by Ibeme »
I just updated and can confirm that it is now no longer moving files on the wrong side. :)
Thank you. ;)
