Transfer from windows to Synology not running
John7
Post by John7 »
I have added a Synology box to replace a old HP mico server. I have installed Syncovery and added exactly the same settings as used in Windows except there it has SSH/SFTP as the option but only SSH is available with the Syncovery version. But I get a auth errer 16 when used. Any ideas how to go from here?
Re: Transfer from windows to Synology not running
SSH in the web GUI means SSH/SFTP.
Please try creating the profile manually, without using the Browse button, so you can run it and get a log file.
Can you send a complete log file to support@syncovery.com, possibly sanitized by removing confidential info?
Or if you look into the log file yourself, you will find some interesting details about the SFTP connection.
John7
Post by John7 »
Thanks got it going, not clear what I did but whatever it was worked! As a query how do I know if/when there is an update?
