I'm running about 10 profiles at about the same time and various of them get stuck on 'Running (Shadow (Xs))' - see screenshot.
If I cancel the job it runs next time without a problem (but another may stop with the same message).
thanks
getting stuck on shadow
- 2024-01-01 getting stuck on shadow.jpg (39.52 KiB) Viewed 11950 times
Re: getting stuck on shadow
shadow copies should be used sparingly. Not more than one profile should be using a shadow at the same time.
Please review your settings in the profiles under "Access & Retries". Turn Volume Shadowing off, or set it to "Use to Copy Locked Files" only.
Most profiles will not need a volume shadow at all. It is really only needed to copy locked Outlook.pst files while Outlook is running. All other jobs, just turn it off.
thanks for the clarification. I will turn off shadow copying.
