Update the Older Version Number on Standard Copying (with Version)
teve
Post by teve »
I have a backup plan with the following settings (on Syncovery 10.8.5 on QNAP):
- Copy Directions: Left to Right
- Sync operation mode: Standard copying
- Versioning:
-- Keep older version when replacing: 5 per file
-- Only on right-hand side
-- Renaming of older version: Add timestamp
-- Filename Encoding: On the right side, put timestamp into all file names
Now, if I were to update this versioning setting from 5 to 3:
-- Keep older version when replacing: 3 per file
Will the backup profile will delete the older version 4 and 5? or not? consider I selected "Standard Copying" sync operation mode?
If not, is there a way to delete those older versions?
Re: Update the Older Version Number on Standard Copying (with Version)
it will delete them for any given file, when there is a new version for a file.
To clean up all older versions even if there isn't a new version yet, you can choose the following checkmark under Versioning->More:
"Clean up all older versions based on the specified number to keep (If unchecked, the limit is enforced only for files that are copied)"
teve
Post by teve »
Thanks for the tips, it works!
Small suggestion, perhaps during the "show detailed status" / "backup preview" page", to show the number of 'older versions removed' too
