Syncovery Scheduler Failing to Start
jasontangyfyj
Post by jasontangyfyj »
Currently using version 10.8.3 and have set up the scheduler to sync files every day at 2:00 AM.
But after the synchronization was completed on November 17, 2023, I logged into Windows at 12:24 noon on the 20th to check, found that Syncovery was not running. When I started Syncovery, the sync auto-started and saw that the scheduler was not executed on the 18th and 19th.
Re: Syncovery Scheduler Failing to Start
the standard background scheduler runs only when you are logged on. And only if you start it, or if you have chose "Auto-Start Background Scheduler With Windows Login" via the Tools and Settings button on the Scheduler tab sheet.
A solution is to install the scheduler as a service. Please see:
https://www.syncovery.com/documentation/faq/service/
