Deleting old archive files
xrsean
Post by xrsean »
We have a lot of old archived files that are no longer relevant. Is it possible to delete them and not mess anything up?
I had the sync jobs set to only keep 2 versions but it doesnt look like that is honored in the way I thought it would and we have zip backups going back 3 years+ that are not needed.
Re: Deleting old archive files
It depends on what your Versioning and Compression settings are exactly, and which Syncovery version you are using.
Can you post the last part of a log file, which lists the settings?
