Syncovery, Cryptomator, conflict
Contractor5Prepays9
Post by Contractor5Prepays9 »
copying d:\data_BACKUP to x:\Data_BACKUP but x: translates to the cryptomator vault (you recommend this) path
if I RUN the profile in attended mode, files DID COPY from left to right.
BUT, if i try to SELECT files to copy, i get the error attached, paramater is not correct, and then i don't see the files on the right side (x:\ cryptomator vault)
the vault is mounted.
ADDENDUM - if i keep right side as X:\Data_BACKUP, it does then see the file list
any info appreciated, thanks
Re: Syncovery, Cryptomator, conflict
unfortunately I do not have any information on this.
I don't think that the error can be from the subfolder selection.
Can you do some more tests with different settings?
Contractor5Prepays9
tobias,
somehow, sometimes, i'm not getting email notification that something got opsted, so i did not see your reply.
i can test this more, later, but currently i have put on hold the larger cryptomator file i was testing (due to onedrive indexing issues).
if i revisit this, i'll post more tests
thanks
nick
