Is there an easy way to see all file version available to restore?
linguy11
Post by linguy11 »
Trying to recover some files that were overwritten both on my system and in the backup. Fortunately, I have versioning enabled so there should be multiple copies of the file in the backup but when going through the wizard my options are to restore the most recent version or to select a date... which for me is unintuitive, I have no idea when the last backup of that specific file was.
Is there a way where I can just visually see all the previous file versions I have so I can pick which one rather than having to select a date and hoping there was a version on that specific day/time?
Seems like there should be some step where the system says "here's ALL the different version of this file/folder you selected, which one do you want?"
Re: Is there an easy way to see all file version available to restore?
yes, you can run a restore profile in Attended Mode and right-click any file and see the available versions in the menu.
linguy11
Post by linguy11 »
Thanks, I'll check it out!
