remove checkmarks on profile after running?
Contractor5Prepays9
Post by Contractor5Prepays9 »
how to automaticaly remove selection checkmarks fro a profile, after running it? they used to turn off after successful run, but now they are staying on.
i can use the REMOVE CHECKBOX opton each time i start the program, to clear them, but was wondering why i can't find the "turn off" option.
thanks
Re: remove checkmarks on profile after running?
when you click the Gears toolbar button, it's under "Running Options".
The checkmarks will be removed immediately when the profile is started, regardless of success or not.
Contractor5Prepays9
thanks !
I was searching forever in "PROGRAM options !!
