Will two way sync work with Syncovery running on a Linux box that maps a Windows laptop share?
IMTheNachoMan
Post by IMTheNachoMan »
I have two boxes:
  • a linux box (main)
  • a windows laptop
I want to do a two way sync between the two. I was doing this previously between two windows boxes. I'm unsure if the Linux version of Syncovery will still work?
My plan was to:
  • share folder on laptop and mount it on the linux box
  • create a two way sync job where the left is my linux box and the right is the shared folder from the laptop
Will this work?
Re: Will two way sync work with Syncovery running on a Linux box that maps a Windows laptop share?
Yes, sure, that is absolutely possible.
There's also an integrated SMB button in Syncovery so you wouldn't even have to mount the folder, but performance might be better with a mounted folder.
