Cannot process exact mirror
roclab
Post by roclab »
I created a new test profile where I did put a bunch of directories there to test the mirror settings combined with versioning.
When I delete some files on the right side (+- 25% of them), I receive the following result message "Nothing to do, deletions disabled" after running the profile in Unattended Mode.
Even after unchecking everything under the Safety unattended mode tab it does the same behavior.
Is there a configuration setting that I am missing ?
Re: Cannot process exact mirror
yes, you have to allow deletions and set appropriate limits in the profile under
Safety -> Unattended Mode.
Most checkmarks have to be placed, not removed.
Only the checkmarks about "special safety checks" should be off.
roclab
Post by roclab »
Thanks, it works.
The problem is that the deleted files were just a bit over 20%, that`s why I got the error.
Thanks again
