Cannot use strong password with Service Scheduler
French Support for Syncovery for Windows
heroes1412
Post by heroes1412 »
i cannot use Strong Password (password with special character such as $ @ ...) in Service Scheduler window. Im using a trial latest version of Syncovery Syncovery64Setup10.4.6 (windows server 2008 R2).
Log file is poor feature. please support HTML format, contain s"uccess file transfered", "error file transfered" fieds...
Re: Cannot use strong password with Service Scheduler
thanks for the feedback.
Note that you only need to give the service a password if it needs to access network paths (UNC paths).
If there is a problem entering the password via the Syncovery GUI, please go to
Windows Control Panel -> Administrative Tools -> Services
and edit the properties of the Syncovery_Service.
