LucidLink sync - creation dates on Mac
farhadd
Post by farhadd »
Hello. I've posed this question to Syncovery support and they're looking into it, but I'm wondering if anyone else has had the same issue. I'm trying to sync files from a LucidLink volume on a Mac to a local directory, and while the modification dates on the files are fine, the creation dates all revert to December 31, 1969 on the local filesystem. If I sync files in the other direction (from Mac to Lucidlink) it all works properly, and if I drag the files manually at the Finder the dates are all correct as well.. Have any of you tried this, and if so, what's your experience been? I will say that doing the same thing on a Windows machine works properly.
Re: LucidLink sync - creation dates on Mac
The creation dates were missing in the macOS catalog info data from the LucidLink drive.
The new version 10.4.2 will now use data from the Unix kernel if it's missing.
