Google Drive File is too big to export from Google Drive: 20870AF
RoyReddy
Post by RoyReddy »
I was copying from Google Drive to QNAP with Syncovery v10.3.17, build 77 (64-bit)
works beautifully until
I get an error with one file, a 13meg Googledoc
(GET https://www.googleapis.com/drive/v3/fil ... l.document)
9:00:19 PM.527 IP Exception (no retry): ETGFTPErrorDoNotRetry File is too big to export from Google Drive: Copy of Workbook Lesson 1.docx @ 00000000020870AF, CP:CorEX4:File is too big to export from Google Drive: Copy of Workbook Lesson 1.docx
Exception File is too big to export from Google Drive: Copy of Workbook Lesson 1.docx at 00000000020870AF.
Filename: ext://Google Drive/LMT Music Theory in Practice/Lesson 1 Pitch/Copy of Workbook Lesson 1.docx
thnx RrR
Re: Google Drive File is too big to export from Google Drive: 20870AF
It's too big. Google Drive cannot convert/export it.
To avoid the error, you will have to write the file name into the exclusion mask.
RoyReddy
Post by RoyReddy »
thanks for the answer
I dont understand the limitation
I am able to download it from Google Drive. and able to Export it from Google Doc
is the limitation with the googleapis
Yes, apparently the API limits this to 10 MB. The API error is exportSizeLimitExceeded.
RoyReddy
Post by RoyReddy »
well Dhat Gummit !
thanks for the reply
