Registration code
champ2152
Registration code
Post by champ2152 »
We are looking to moving the syncovery software to another computer.
What is the best way to do this or is there a way to get the registration code from the current software that is installed
Re: Registration code
you can just reuse your license code.
If you would like to preserve your settings, please copy the Syncovery.ini file over to the new computer. It is usually in the folder
C:\ProgramData\Syncovery
Note that the ProgramData folder is hidden and not to be confused with Program Files.
If you just want to find your registration name and code, you can look for RegName and RegCode in the Syncovery.ini file.
champ2152
Post by champ2152 »
Great Thank you.
