Syncovery Web SSL Certificate
tiagocoelho2
Post by tiagocoelho2 »
Hello.
I'm encountering a problem with the SSL certificate for Web Synccovery. The configuration of the certificate path is for example: "C:\Scripts\Certificados\Certificado testx\", but when not finding the path or for another reason that I have not discovered, it is changed to the default path in C:\ProgramData\Syncovery \Database\". Is this a bug?
Re: Syncovery Web SSL Certificate
no, this is not a bug. It creates its own certificate if necessary.
