Connect to remote sftp from Synology
slewrate
Post by slewrate »
Hi there,
I'm having trouble getting syncovery (synology) to connect to a remote sftp server.
I can connect to the same server with Filezilla just fine.
This is on the error logs:
Connecting with *********.143
***** Left Side: : SFTP CONNECTION STARTS *****
Using SecureBlackBox 16.0.329.0
Left Side: : SSH Exception: Connection error 110
05:34:06.800 IP Exception (3): EElSimpleSFTPClientError Connection error 110 @ 0000000001188CD0, CP:SBBCoEx:Connection error 110
ERROR
sftp://*********.143/www/wwwroot: Cannot access sftp://*********.143/www/wwwroot
(Connection error 110 at 0000000001188CD0)
Re: Connect to remote sftp from Synology
please make sure the checkmark "Use TGPuttyLib SFTP Implementation" is chosen on the Internet dialog in the profile.
You may also want to update Syncovery or upgrade to Syncovery 10.
