Running a Pascal Script on the start of a profile
semaj4712
Post by semaj4712 »
I think I have this code correct, but It does not seem to be triggering or maybe it is, but I cannot tell, ultimately I am not getting the result I would expect on the other end of this request.
function OnCanRunProfile(const ProfileName: UnicodeString; var PostponeBySeconds: Integer): Boolean;
var
  ntfy_username, ntfy_password, PostData, AdditionalHeaders, URL, Response, ErrorResponse: AnsiString;
  ResultCode: Int64;
  ntfy_username := 'username';
  ntfy_password := 'password';
  PostData := 'Backup of the Master Output share is starting';
  AdditionalHeaders := 'Title: Syncovery Backup Starting...'+#10#13+
                     'Priority: default'+#10#13+
                     'Tags: arrows_counterclockwise'+#10#13+
                     'Authorization: Basic ' + EncodeBase64(ntfy_username + ':' + ntfy_password)+#10#13+
                     'Content-Type: application/x-www-form-urlencoded';
  URL := 'https://ntfy.url.com/Beltzer';
  ResultCode := 0;
  Response := '';
  ErrorResponse := '';
  if SendHTTPRequest('POST', '', AdditionalHeaders, URL, PostData, ResultCode, Response, ErrorResponse) then
    // HTTP request was successful, do something with the response
  end
  else
    // HTTP request failed, do something with the error response
  Result := True; // or False, depending on your requirements
Obviously username, password, and url have been redacted
Please let me know if there is any obvious issues with this code
Re: Running a Pascal Script on the start of a profile
can you try the following hook instead?
function OnGetProfilePathBeforeListing(const isRightSide:Boolean;
        var Path,UserName,Password:UnicodeString;
        var AuthKey,AuthKeyPassword:AnsiString;
        var Port:Integer):Boolean;
This will be called as one of the first things when the profile runs. It has the advantage of being able to use the Log function like this:
Log('Calling HTTP Request Now.');
The hook you used is called by the scheduler, which means you can't use the Log function.
semaj4712
Post by semaj4712 »
Is there something I should be looking for in the logs, I see the Pascal script in the summary, but nothing referencing it other than that
There should be a line saying:
"Successfully compiled the profile's script."
Other than that, you need to add logging to the script by calling the Log function.
The lines will be in the log file.
semaj4712
Post by semaj4712 »
I figured out the issue,
+#10#13+
should be
+#13#10+
True! Should have spotted that myself ...
