Automatically save/backup configuration and profiles
IMTheNachoMan
Post by IMTheNachoMan »
Is there a way to schedule automatic backup of Syncovery configuration and profiles?
Even better if it only backs up when something changes.
Re: Automatically save/backup configuration and profiles
you can create a profile that backs up the folder C:\ProgramData\Syncovery.
You can set subfolders to "None" to avoid backing up log files and databases, which you don't need.
All the settings and profiles are in the main folder.
IMTheNachoMan
Ah. Clever. Use a backup software to backup the software's configuration. Ha. Love it. Thanks!
