Dark theme tabs difficult to use
richard.bourque
Post by richard.bourque »
I'm evaluating Syncovery and like what I see so far.
I almost pulled the trigger and purchased Beyond Sync but accidentally came across this and see that it has more features and is a better price.
My preliminary tests are good, except it took me FOREVER to find the "Monitoring/Real-Time Sync" tab. On a 4k screen with dark theme the tabs aren't even visible on my laptop and external monitor. It looks like a jumble of text that says "Schedule More Weekdays and Time Window Monitoring / Real Time Sync" like a run on sentence! Spacing it out a little, or making the tabs with a little more contrast sure would make it a lot easier to read. Also it's impossible to see which tab is selected.
Just my 2 cents, otherwise an excellent program.
Richard.
Re: Dark theme tabs difficult to use
I can see what you mean. There is a very fine line around the tabs from which you can deduce which tab is active.
But you can switch to a different visual style. To do that, please go to the Profile Overview and click on the Gears toolbar button and choose "Themes and Colors". I would recommend the "Glossy" style but there are many others that will work.
richard.bourque
Much better!
I've already purchased a family pack license.
Thanks again. Awesome product.
