ZIP files, windows will not open them?
Contractor5Prepays9
Post by Contractor5Prepays9 »
question
source to destination, ZIPPED files/encrypted files on destination. your default is 256.
IF i go to my OneDrive and DOWNLOIAD one of those files by itself, and try to open it in windows, windows compressed folder will not open it.
I have to use 7-zip. (I CAN do that, and i can use the restore if needed)
Now, see attached, you have several zip methods. if i want to occasionally share one of my ENCRYPTED files with a family member, and they have the decrypting password, which of these protocols WILL work with windows zip file system, and not need 3rd party?
i realize that 256 is the best encryption, but if i want some compatibility, and files are not very sensitive, what else would work?
thanks
Re: ZIP files, windows will not open them?
your only chance is classic zip password, but not recommended. No idea why Windows doesn't support AES-256.
Contractor5Prepays9
thanks, no problem.
will stick ith aes 256.
windows aparently just supports the zipcrypto, never changed....
nick
