PCloud: Verify integrity not complete?
mareike1988
Post by mareike1988 »
I am opening a different topic here, because this is not a problem with errors more a question.
I a doing a verification of integrity with "test all files".
Run 2: Result is
"Tested OK/Corrected Files: 68650 tested(116,4 GB <- 49,3 GB) 0
Error with 2 files
1. ... (transfer problem?)
2. ... (transfer problem?)
(between Run 1 and Run2 there was some uploading)
Run 1:
Result is
"Tested OK/Corrected Files: 68543 tested (120,8 GB <- 49,3 GB) 0
Error with 31 files
... (sum had invalid files).
Question:
The total uploaded files consist of the 116,4 GB - 120,8GB....
Were only 49,3 GB tested? If yes, why?
How can I ensure a total verification?
Is there notenough disk space available?
Was the connection interrupted on my or on the PCloud side?
How can I diagnose this.
Thanks.
mareike1988
Re: PCloud: Verify integrity not complete?
OK is the possible reason that the zipped files are so much smaller in size ( 116,4 GB <- 49,3 GB) ?
this notation:
120.8 GB <- 49.3 GB
means that 49.3 GB compressed files were uncompressed to 120.8 GB
mareike1988
OK so false alarm on my side.Thanks.
