[solved] WebDocs not found in SyncoveryCL-x86_64-9.48n.tar.gz
Jean-Michel
Post by Jean-Michel »
Hi
I would like to test Syncovery on Lubuntu 22.04 LTS
I've downloaded SyncoveryCL-x86_64-9.48n.tar.gz, extract the content which appears to be only those 4 files:
-rw-r--r-- 1 barbu barbu   208065 janv. 25  2022 cacert.pem
-rwxr-xr-x 1 user  user  5018176 déc.  28  2021 libtgputty.so*
-rwxr-xr-x 1 user  user   2566104 août  26  2020 puttygen*
-rwxr-xr-x 1 user  user  26240296 sept. 25 10:55 SyncoveryCL*
Executing those commands:
user@test:~/Téléchargements/CL$ ./SyncoveryCL SET /WEBSERVER=localhost
17:32:10 SyncoveryCL v9.48n
17:32:10 Initializing
17:32:10 Log folder: /home/user/.Syncovery/Logs
17:32:10 Configuration File: /home/user/.Syncovery/Syncovery.cfg
17:32:10 Storing global settings:
17:32:10 Configuring web server for localhost, port 8999.
17:32:10 Web Docs Path: /home/user/Téléchargements/CL/WebDocs
17:32:10 Username: default
17:32:10 Password: (hidden)
user@test:~/Téléchargements/CL$ ./SyncoveryCL start
Launching Syncovery v9.48n (64 Bit) daemon
However as no WebDocs folder is available, openning http://localhost:8999/ in browser results in "Error : file not found"
Where am I supposed to get the WebDocs files from ?
Jean-Michel
Re: WebDocs not found in SyncoveryCL-x86_64-9.48n.tar.gz
in general, it's better to use the Debian package:
https://www.syncovery.com/release/Synco ... -amd64.deb
and install it with sudo dpkg -i Syncovery-9.48n-amd64.deb.
However, if you want to stick with tar.gz, you need to download the package labeled "(With Web GUI)":
https://www.syncovery.com/release/Synco ... Web.tar.gz
Jean-Michel
Thanks a lot Tobias
I totally missed that the right column was that.
