How to run profiles in sequence one by one?
Redwood
Post by Redwood »
How to run checked or selected profiles in background in sequence one by one?
I set "Maximum simultaneously running jobs (profiles)", "Max. simultaneous jobs to run in a single execution process" and "Lifespan of a profile execution process (number of jobs)" all to 1 but it had no effect.
What are those parameters for?
Re: How to run profiles in sequence one by one?
these parameters only affect scheduled jobs.
If you run jobs manually, you can right-click and choose "Run in Unattended Mode", which runs them in sequence. As opposed to background mode, which runs them simultaneously.
If you need to work with Syncovery while it's running jobs, you can open it a second time.
Additional information about chaining profiles can be found here:
https://www.syncovery.com/documentation/faq/chaining/
