Sort files
The RedBurn
Sort files
Post by The RedBurn »
In the "Synchronization Preview" window (file list), we should be able to sort by size.
Currently (version 8, haven't tried 9), the size isn't shown in the Size column, it's shown in a sort of fused column and we can't sort anything.
Sorting by size is especially useful to check the biggest folders first.
Re: Sort files
thanks for the suggestion! If you speak of "biggest folders", that would mean there should be two options:
- sort by file size
- sort by folder size
I will consider it.
