attach files to email?
Knarf
Post by Knarf »
Is it possible to email the file I just synced?
(job, Override email settings)
tnx
frank
Re: attach files to email?
not directly, but you can create a separate profile with "Email" as destination.
Can you describe the use case in more detail, so I can recommend how to connect these profiles exactly.
Maybe it can be done with one profile. It depends on what your other source and destination are (local or FTP etc), and if you are "Moving" files, or "Copying".
Knarf
Post by Knarf »
ah yes. thanks! I remember now. :D
