Please Ignore - accidental post
DrkMstr310
Post by DrkMstr310 »
Edit: post removed (accidentaly posted about the wrong software!)
Re: Conflicts Whenever A Device Is offline (file only edited in 1 place)
a name like "sync-conflict-xxxx" is not from Syncovery.
Apparently you are using a different tool. Make sure all other sync software is disabled when you try Syncovery.
If problems remain, please send log files to support@syncovery.com.
You can open the Logs folder via the File menu -> Show Log Folder.
DrkMstr310
Please ignore - accidental post
Sorry, I'm embarassed!! The issue was Syncthing, and I knew that app was the problem, but somehow my brain mixed up the names "syncthing" and "syncovery", so I posted int he wrong place. Sorry for the bother!
