Hi.
- Legacy encryption:
I leave encryption in legacy mode. After an installation of syncovery, services and restore syncovey.ini, it returns to "medium safe" mode.
- Certificate gui web interface failure:
After an install of syncovery, services and restore syncovey.ini, including the certificates to the defined directory, the https web page fails to load. To solve, you need to manually enter syncovery and open the settings and apply.
Syncovery 9.47G. Windows.
Legacy encryption and web gui issues. Syncovery 9.47g
tiagocoelho2
- No legacy encrypto.jpg (129.46 KiB) Viewed 7420 times
- Cert web gui.jpg (103.25 KiB) Viewed 7420 times
tiagocoelho2
Re: Legacy encryption and web gui issues. Syncovery 9.47g
Solved: copied Status.ini file
yes, there are now multiple ini files. The most important data is still in Syncovery.ini, but data that may change more frequently is stored in other ini files. The idea is to protect the main configuration and profiles better because the main ini file will be modified less often.
