Mask ignored sometimes
sfc_scottr
Post by sfc_scottr »
I have 2 jobs that are identical except for the right-hand destination. They both have "all files" for inclusions and the same subfolders selected for action.
Both jobs are only triggered via the command line and are always passed a MASK value. The MASK list is semi-colon delimited and is the same for both jobs. In fact, out of concern they may not be the same, I recently updated the trigger to use 2 RUNX switches to call both jobs with 1 command, ensuring the same MASK value.
The issue is that while job 1 only copies the files indicated in the MASK parameter job 2 copies any files that have changes within the allowed folders. It does honor the exclusion list, but I only want to process the files in the MASK.
I've manually reviewed/compared the 2 jobs. What could I be missing that would could this behavior?
Re: Mask ignored sometimes
please post complete log files and the command lines you used.
You may prefer to send them to support@syncovery.com rather than posting here.
sfc_scottr
Thanks, email sent.
