Internet Links not synchronized
unweal
Post by unweal »
I am not able to synchronize ".url" files. I have a huge number of internet links and they do not show in the sync window.
For now, I have to select "unaffected" and "one side" to see them. Then select all of them and 'Copy Left to Right"
Is there an easier way to automatically do it?
Thanks,
EDIT: It is a 1-way sync from computer to GDrive pro account.
Re: Internet Links not synchronized
thanks for the report, I will fix it. Currently .url files are excluded because the same extension is used for other purposes: when downloading from Google Drive, there's an option to create links to Online Docs. But I can enable url files to be uploaded if this checkmark is not chosen.
unweal
Post by unweal »
Thanks !
For now, I will continue by doing it manually.
Contractor5Prepays9
Post by Contractor5Prepays9 »
hello - again
url files, is there a checkmark, i am having same issue?
thansk
nick
are you syncing with Google Drive too?
Contractor5Prepays9
i use onedrive
and somehow i need to try and recoup the URL links that are on the partially decrypted d: drive (it is now out of the chomputer case)
the MAIN THING is to be able to go between c:/d: and backup drive M:
OK this has nothing to do with this thread. I don't know what your problem is. To get more detailed support, please send screenshots and a log file to support.
Contractor5Prepays9
tobias, sorry.
re: the thread, yes, it relates - where is (or is there) the checkbox mentioned above, about allowing the URL's to be copied?
i don't use google
the copy operation this relates to is copying from my c: drive (which has some url's i have saved), to my M: drive (my backup drive)
the URL's always show as not copied.
the REST of the issues noted, just ignore them (they relate to the failing drive that started all this, i am delaing with that, and a BIG THANKS to syncovery for its reliable backup to my other drives, making the restore from this failing one possible :-)
URL files are always copied, no checkmark necessary.
The only exception is with Google Drive, where URL files are used for other purposes.
