Files in C:\Users\username\AppData\Roaming
ChaosX
Post by ChaosX »
Following a recent update, Syncovery is spawning files in C:\Users\username\AppData\Roaming instead of C:\Users\username\AppData\Roaming\Syncovery
Bug?
Re: Files in C:\Users\username\AppData\Roaming
I don't think this has changed, but because the number of INI files has increased a lot, it would be better to move them into the Syncovery folder.
I will think about how to do that in a safe way.
The default folder is C:\ProgramData\Syncovery, and there it really puts everything into the Syncovery folder.
ChaosX
Post by ChaosX »
tobias wrote: Wed Feb 16, 2022 6:46 pm Hi,
I raise this again as the files are non-descript and live in ...\Roaming root, unlike every other app. Without Syncovery, I would have only a single file that isn't in a subfolder under "Roaming".
The thing is that my housecleaning wiped all these files, only to discover days later that Syncovery was blank and inactive.
A little house-keeping please. FWIW, I have no preference between \User\AppData\Roaming or ProgramData\Syncovery... :D
Thank you!
you just need to choose the default Syncovery.ini location on the Program Settings dialog, tab sheet "Prefs".
It should be "one INI file for all users".
Then it will all be in the folder C:\ProgramData\Syncovery.
