WOL magic packet feature?
ChaosX
Post by ChaosX »
Is it possible for a task to trigger WOL? Presently, I must do this manually w/Nirsoft's WakeMeOnLAN.
Re: WOL magic packet feature?
you can invoke an external command line or other tool or script via "Execute before/after" on the Job tab sheet in the profile.
I will consider adding such a feature natively.
ChaosX
Post by ChaosX »
Thanks. I'll give that a shot. The 2-minute lag time should be plenty. I may trim that later.
