B2 Broken in Synology 6
ChaosX
Post by ChaosX »
Apparently, since November 1, my B2 backups have failed. I updated to "y" tonight, and still no success,
When I enter the ID and key I am met with an error that says...
Using the Windows version, I am able to connect with the ID and key. Seems something is broken in Synology,
Please advise!
Re: B2 Broken in Synology 6
it works fine with the latest Syncovery version 9.39y on Synology DSM 7.
Please update at least Syncovery. Which version do you have?
Syncovery Versions older than 9 are no longer supported or updated.
I can't test it on DSM 6 right now but I will try to get a DSM 6 machine.
ChaosX
Post by ChaosX »
I am using DSM 6.2.4, and 9.39y.
many thanks. I will get a DSM 6 box today. Most of my Synologies are DSM 7 already.
B2 updated server certificates and other things and may require a newer SSL library. I will see what can be done. Maybe I can include the newer one with Syncovery if the Synology one is too old.
ChaosX
Post by ChaosX »
Coincidentally, Windows 9.45c works fine, however I have to download from the NAS to the PC and then upload to B2, in the meantime.
Maybe there's a cert difference between those two.
And apparently I need to figure out task failure communications, as I've missed two months of backups.
yes, there's a Notify tab sheet on the Program Settings dialog.
ChaosX
Post by ChaosX »
Hi Tobias... Have you been able to duplicate this with B2/DSM6?
yes, it is fixed in Syncovery 9.45.
ChaosX
Post by ChaosX »
That seems to have worked ... thank you.
