Backup once every 2nd week
Lars
Post by Lars »
I'm looking for a way to elegantly have a weekly chained backup to two different switching target folders. The " $2WEEKSDAYS" variable comes close. But due to the fact that the chained backups might take longer, the weekdays the idividual backups start are not set. I was woundering if there is some variable one youd use fpr odd and even weeks of the year?
Regards, Lars
Re: Backup once every 2nd week
sorry for the delay, it is possible with a PascalScript. I will post one ASAP.
Lars
Post by Lars »
I would still be interested in a possible sollution?
Regards, Lars
again sorry for the delay. I can send you a script and/or Syncovery update today.
So the destination path would alternate every 7 days between for example
D:\Data\ODD
and
D:\Data\EVEN ?
Is that correct? Or how would you like the odd/even folders named?
Also, does your week start on a Monday or Sunday?
OK here's a sample script that adds ODD and EVEN to the end of the right-hand path, alternating every 7 days. It's not necessarily the same odd/even of the official week of the year, but it alternates correctly across years.
In this function, a new week starts every Monday.
If the right-hand path uses forward slashes, such as for FTP or cloud paths, you need to replace the backslashes in the function with forward ones.
function OnGetProfilePathBeforeListing(const isRightSide:Boolean;
        var Path,UserName,Password:UnicodeString;
        var AuthKey,AuthKeyPassword:AnsiString;
        var Port:Integer):Boolean;
var today:Integer;
  if isRightSide then begin
     today:=Trunc(Now)-2;
     if (today div 7) mod 2=1 then
        Path:=ConcatPathWithDelim(Path,'ODD','\')
     else
        Path:=ConcatPathWithDelim(Path,'EVEN','\');
  Result:=true;
Lars
Post by Lars »
Tank you! I will have a look and test it.
