Sync getting triggered by Client
Superbrka
Post by Superbrka »
Is it possible to trigger/request sync job (Server -> Client) locally from the Client using "Syncovery Remote Service" ?
Thanks !
Re: Sync getting triggered by Client
no, but it would be possible using the browser based GUI that you can enable on the Cloud tab sheet of the Program Settings dialog.
Of course it depends how far away server and client are. Are they on the same LAN or VPN? Then you can access the browser GUI by entering the server IP address and port 8999 in the address bar of your web browser.
If on the same LAN, you can also use File->Tools->Monitoring Tool on the client to run jobs on the server.
The Monitoring Tool also works over the Internet, but it's more difficult to set up. See also
https://www.syncovery.com/monitoringtool/
